Check Engine Light
jesusm1
hi
My car has the check engine light on , and since any physical defect I see or hear, I believed that one of the two oxigen sensors is bad. So I changed both, reset the error (disconnect the battery) run the car several times and the check engine light will display again . What could be wrong? :crybaby::crybaby::crybaby::crybaby::crybaby:
How many miles are on your Paseo and when was the last time you had a MAJOR tune up? Is it running rough at all or consuming more gas? Let me know all the details...
thanks for your reply:
My Paseo has 141k. At 60k and 120k I replaced the timing belt and seals. Right now is running fine. Soft starting like new. No abnormalities when the engine is idle.
I'm the first owner and I very proud of the service my Paseo brings me.
Any help will be fully appreciated
mmm.... I never changed the spark plugs wires before....
Do you think that the ECM could be with problems?
Do you know if Toyota vehicles have a way to get the error codes without a scanner (ie as pontiac when the check engine blinks several times by shorting two points on the diagnosis tester connector)?
