Trouble With Cold Starting And Strange Sound
avensis_toyota
I have Avensis 2005 2.0 D4D 115 KM. Car have a problem with cold engine start it need some time to start. And when it finaly start and I let it running in idle, I can hear inside the car (but outside it is really hard to hear it) some strange banging sound like someone would bang with a small hammer. The sound it is not repeating in the same intervals, but it is different. In summer everything is normal!
I have a new Battery, new glow plugs.
It run similar as this one:
Is there some problems or this is normal or.... ?
Thanks!
Our Verso was doing this last winter, it would also produce a cloud of smoke at the same time and it would not rev up properly for 30 seconds, after this it was ok. The fix was injectors under warranty, fuel was not the issue for us. The car had done 60,000 miles/100,000 Kms at the time.
The car still drove normally but as it was under warranty Mr T changed the parts, the cold exposed the worn injector's.
I have a new battery, new glow plugs.
Thanks!
hi mate
- test glow plugs;
- test + calibrate all four injectors as they are due to be tested by 60k
all you said + video confirm an over fueling effect with character hummer noise.
Cheers/Igor
hi mate
- test glow plugs;
Cheers/Igor
What do you mean by "calibrate all four injectors"? How is this done - by a Toyota tester unit, pluged into the OBD or you should take them off and use another machine.
hi mate
- test glow plugs;
Cheers/Igor
no i meant each injector cycle diesel portion and jet quality to be equalized to have an equal load in each cylinder.
cheers
