Armrest Storage Divider
Davrav
Had a bit of spare time at the weekend and came up with this:
Just helps to separate the bits and bobs.
Sits on the two ledges front and back of container.
I used a piece of 2mm Model makers styrene sheet that I had around [can be scored with a stanley knife and snapped like glass] and bought two A4 sheets of black self adhesive 'Fabfoam' from Hobbycraft. The ribbon is held in buy double sided tape under the foam. Total cost £1.78.
Could use 3mm MDF or any other easily cut rigid sheet.
No idea if anone else has done this but if you would like to, PM me your e-mail adress and I will forward you a measured drawing [working out the template was the longest part of the job]
I also have a simple suggestion to make it look like the actual base of the container to create a hidden compartment but I don't want to publish that here ;)
If I bundle this with the rear midway parcel shelf it might make a nice little "storage solutions" item in the pinned section. Is that OK?
Fine by me.
