Changing Bulb In Boot
brianbj
Please could anyone tell me how to get to the bulb in the luggage compartment of the 2005 Avensis T4 Hatchback please. To me it appears that I would have to prise off the lens but I am afraid to try it in case I broke the lens. Many thanks in advance,
Brian
Does your handbook not tell you how to do it :huh:
Brian
Not sure about the 2005 model but most cars rear light cluster is reached from inside the boot by removing part of the boot trim and a plate holding all of the bulbs can be removed.
Fitter
Brian
Fitter
The light for the luggage space is not in the rear light cluster, it is situated on the nearside inside trim about halfway along the side of the boot and the lens ( possibly plastic) is flush with the trim, but thanks for the replies.
Does anyone else know please?
Brian
Brian
Fitter
Brian
The light is probably a spring fit on the luggage trim. If you prise your fingers under one end of the light, you may find it just springs out. If it does, then you should be able to undo the wire connectors and retrieve the light unit for inspection. I wouldn't force too hard as this may not be the case, but I have the same model and will have a looksee at mine tomorrow.
Brian
Fitter
Brian
Sorry about that. I diidn't read your request properly. The Trunk light lens can be prised off using a flat headed screwdriver to access the bulb.
Fitter.
Brian
Fitter
Brian
Fitter.
Many thanks for all answers From Fitter and others.
Brian
