St205 Help
licksrpm
right i have spoke to a few people one guy was verry helpfull . i asked wot are the safe limits for my car an st205 gt4 !" i was told 350bhp standerd internals and to pump the turbo 1.1 bar is the safe limit . i then found thread and his car blew the piston ring i only one to run say 300 310 so a nice amount above standerd with out goin crazy please help i need all the info i can get i will try to return the favour cheers !
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
  • licksrpm
    33
  • Fawbs
    26
  • ajcluck
  • Insanity-74
Posted Images
350 is usually the standard limit on oem internals, however there are people running 400bhp on oem internals because of good cooling mods. 300bhp is easy for this car and will run at 300 happily all day. Its all down to how you drive and how you take car of your car. Oil change every 3000-5000 miles, use good oil like millers or Opie, good servicing, keep an eye on everything and dont thrash it every second you drive it. Blocks crack, rings blow etc even at running 255bhp which is the stand horse power.
One way to protect against rings and that going is keeping temperatures down. Adding an oil thermostat to open at 80 degrees i think it is and adding an additional oil cooler is definitely a certain on this car as it explains on the gtfour website that people have experienced high oil temps on normal road use. Bigger radiator even though the standard one is fine, aftermarket coolant thermostat with lower opening temperature, some top notch coolant (ask dawesy for the stuff he uses), front mount intercooler, cold air box with a good cold air feed, take the engine cover off the bonnet, add a header tank and swirl pot to the coolant system but be careful as you could cool the coolant too much and cause problems so a water temp gauge is a must, disconnect the coolant hoses to the throttle body, install water injection, install a spray bar for the front mount intercooler. Thats all i can think of and those last 2 you probaby wouldn't need plus they are a bit pricey and i'd imagine you would need an aftermarket ecu to control them but they are worth it once the horses begin to rise,but things vary, might have the same engine as me but you could take mine to 500bhp and it will not blow, could take yours to 300 and it may go boom but its highly doubtful. 300bhp for you will be no problem just get some good cooling mods on your car to safeguard its life and you will be laughing all the way home. Definitely doing the right thing researching it, usually i put a mod on my car then read the downside of it ha.
I'm sure you could even lighten the car a bit like removing the air con and putting less stress on the engine as it won't have to haul so much around. Not sure if this will make much of a difference but just a guess, who knows.
Mike
be careful if you are cranking the boost up to 1.1bar and have suporting mods like decat as this tends to introduce boost creep. thats how i blew my engine!
But if u get a 2.5" downpipe they don't tend to creep its the 3"' that usually creep.
yeh i really should have done that in the first place! i have a custom made job now its 2.5" but before i just cut out the honeycomb!
so at 300bhp is the cooling system in need of an upgrade ? i was hoping to get a bigger rad for starters can not find any though . but i hav looked and looked for the 2.5 bore downpipes or fullsystem i can only find 3" bores where can i try for these parts n thanks il get there im just trying to take alot in
im goin to ditch that crap atached to the bonnet it can only be keepin heat in there and i have seen the boost controller i want wich has n over boos warnin so fingers crossed il have to just hunt for cooling help
Yeh most stuff is 3" but there are 2.5" downpipes out there. If you get a downpipe remember to wrap it in exhaust wrap to help the flow. Take a look at what? www.fensport.com do a 71degree thermostat i think it is, TRD i think. I'll find you some stuff to look at and you can see what i mean.
470 quid for a radiator, i wouldn't even bother unless you are filthy rich this is the one i used
http://cgi.ebay.co.uk/TOYOTA-CELICA-RADIAT...=item45eea0a011
Fits straight in yes its a cheaper radiator and i cant give u much feed back coz i didnt have a water temp gauge but it cooled the car down quick when u left it standing for 10 mins or so.
No that is a new one and that thermostat you can get at www.fensport.com. Problem with nengun is its in japan and will probably need to add another 100quid to the price of that rad on there for postage. Shall i list you some sites i use for parts and info?
That rad works well for me, rad cap is a bit crap but if it messes up you can always get one made up for u.
www.gt4dc.co.uk
http://www.celica-club.co.uk/
www.gt4oc.net
http://flatlander-ipp.nl/404.shtml
http://www.k1ano.co.uk/
http://www.celicatech.com/
http://www.blitz-uk.co.uk/
http://www.xs-power.co.uk/ this site is a bit hit and miss with their parts there can be fitment issues
http://www.tcbparts.co.uk/ great place to get cheap parts and all sorts
www.japarts.co.uk
www.turbosmartonline.com
www.turborevs.org
http://www.sapmotorparts.com/
http://www.demon-tweeks.co.uk/
http://www.wolfkatz.com/ good for new fuel rails
http://www.millersoils.net/ oil i use
https://www.paints4u.com/ paint
http://www.jap-spec-performance.co.uk/
http://www.europerformance.co.uk/
http://www.v6z24.com/mods/howto/images/plugs/plugs19.jpg nice little article about spark plugs, great info
www.toyodiy.com good for part numbers
http://www.futuremotorsports.com/index.php...a3eefa3c9070f8d
http://www.prolex-uk.com/
http://www.powerflowexhausts.co.uk/
http://www.thor-racing.co.uk/
http://www.greenline.jp/catalogue/bcmakerlist.php
http://www.nemesisuk.com/magnaflow_website/
http://www.madmotors.co.uk/catalog/toyota-...cc077b8b45cda3d
http://www.jdmperformance.co.uk/
http://www.performanceunlimited.co.uk/
http://www.japanparts.com/
http://www.thinkauto.com/acatalog/Product_Summary.html good for oil coolers, hydraulic and oil fittings, hoses etc
http://www.tuningdevelopments.co.uk/products.php?cat=37
http://www.importtuner.com/tech/impp_0808_...mods/index.html
http://www.gt4ec.net/forum/modifications/m...a8a417d6f252675 thats the Battery relocation thread i used
http://www.green-filter.co.uk/index.php got my air filter from here
http://www.flatoutrun.com/index.php?osCsid=autazjirzcp apart from group buys this is the cheapest place to get sard injectors that ive found so far
http://www.aclperformance.com.au/Toyota3SGTEBearings.htm
http://www.japanesecarimports.net/
http://www.tbdevelopments.com/
http://www.horsepowerparts.com/index.php?content_id=1
www.fensport.com
not really its basically sticky back thick foil which u stick on the bottom and sides
In fact i think i have some in my cupboard
ummm iv never realy heard of or seen any heat resistant matting so do you line the bottem of your top mount cooler?
Yeh bottom and sides, i think its called lagging the charge cooler. It reflects heat and will shave a few degrees off temperatures and help the air going into your engine to be cooler.
http://media.photobucket.com/image/gt4%20c...bEvo5/GT4-H.jpg you see the silver stuff matting on the charge cooler. I had this on my charge cooler, no where near as neat as that ha but i had it on. Let me check how much i have cause i dont really need it anymore, give us a few quid for postage and u can have it if u like but if u want to get your own you can get it at http://www.demon-tweeks.co.uk/
