Coilovers/struts To Suit Eibach Springs
lonepilgrim
Hey fellow Rollers,
I currently have Eibach Springs with a 40mm drop on standard struts but need to change these for coilovers ASAP. Can anybody suggest the struts i can use with these springs or do I need a full coilover kit (springs and struts)??
If it's a full kit can I have some recommendations please
hi,i would go for the BC coilover set if i were you . I think there around £630 .I have no experience with them myself but other people have said there very good and i would buy them myself if i could afford them.or there's the Tein set which are also very good.
So you'd recommend a new set up and sell the Eibach's?
Where are you based in Somerset, I'm located in Devon
well i guess it depends what you wanna do . do you wanna lower the car more or just get a firmer ride? if you wanna lower it more then yes defo go for the BC coilovers . i currently have the Eibach spring kit too and wanna get the BC coilover set one day . you could sell the Eibach springs im sure .
based near Taunton .
well i guess it depends what you wanna do . do you wanna lower the car more or just get a firmer ride? if you wanna lower it more then yes defo go for the BC coilovers . i currently have the eibach spring kit too and wanna get the BC coilover set one day . you could sell the eibach springs im sure .
I want to raise the ride height at the front and lower the back end
