Fault Codes
blutto
Just got the compressor back from having a service at Mr T, mentioned when I took it in that I was unsure if the traction control was functioning properly, they told me when I picked it up that it was showing fault code C 1203.
The code was cleared and did not come back on again, the t/c light now comes on when it spins up but I still have to come off the gas rather than the t/c killing it. Dose anyone know what this code referes to and could it have been triggered by my heater /airbag probs when the connector block came adrift behind the dash.
sorry to go slightly off topic but you were saying about ur block coming loose behind the dash, had you an airbag light come on or how did you know? my brother in laws rolla has an airbag light on and Mr.T said its a spira cable, iam now thinking may be a loose connection block either
Yeh pull up the gear stick gaiter then the plastic surround (just pulls up) remove two screws at the bottom of the heater control panel and pull away, you will find a few conections but one big one with mutiple pins, mine was was not completely out but just enough to to make and break the connections. Once it was pushed back in and clicked home every thing was sorted, might be worth a try not gona cost owt.
I take it no one knows any fault code numbers then.
m , no, wont lie, but as you say it would be worth taking a look to see if that connection was loose, cost nout as you say, his car has been diagnosed wrong before with Mr.T, but ill try that and if not will have to get the cable, ill let you know, cheers lad
