Engine Light On Hmmm
frainy
well firstly a couple of weeks back my car was runing like a baag of nails and the engine managment light came on and the trc light and the vsc light in the end i changed my maf sensor and it runs fine lights off jobs a good un then a couple of days later the same lights come bac kon but runs smoth as you like still i took it to thte garage t get the code read and it was saying my car is runing to rich has anyone had this problem and if so how did you get across it ? but there is an actully code for the maf sensor cause i thogiuht it might be that hmmmm any input grately appreciated thankyou frainy
Did you clear the original code in the ECU after fitting the new MAF sensor ??
If the MAF is faulty, the ECU will go into fail safe mode (limp home as opposed to walk home) and put on the Engine Management Light - code P0100 will be stored in the ECU.
If the engine is running rich, the fault may lay elsewhere apart from the MAF and generally you will get fault code P0171 (engine rich).
Some of the things to check are :
PCV valve
Air induction system
Injectors
Mass air flow meter
Engine coolant temp. sensor
Fuel pressure ( regulator hose off/split )
Gas leakage on exhaust system
Heated oxygen sensor circuit faulty
Hope this helps
Mick
Genuine toyota air flow meter or e bay one?
yea it was a replica off eBay do you think that it is good enought to work but not as good as the proper one causeing it to have the engine lights on ?
thankyou for the reply i will look at all the problems u just said will keep u posted thankyou frainy
I bought one of those before. I had the same problem with it, engine ran to rich with it.
ar right ok i will get a proper one did u get u get the lights as well ? frainy
Yea all three
Yea all three
thnakyou for all your help frainy
