Recharging Avensis 2002 Battery
jacsal
Can I recharge my 2002 avensis Battery without removing from the car so long as I disconnect the negative lead to ground. Does the security system and audio need resetting afterwards?
Yes,
You would need to reset the security-system and radio too. But why disconnect the Battery before charging it?You should have put this thread in the Avensis section.
