Engine Start Button
KPARRIS-JONES
Hi, how can I wire in an engine start button?
The panel I am looking at has a kill switch, start button and 3 toggle switches. How do I wire them up, i.e. what to what and from what?
And the most important of all, can I get it so that I turn the key in the barrel, but so that the actual start is down to the button?
I don't want to rid myself of the keys use for obvious reasons, this being a very nickable car and all.
Thanks for any help and/advice given,
KPJ
just run it along side the key....... the button essentially does the same as turning key from pos 1 to 2. ie, connecting starter motor etc. then when you release the button as you would a key, circuit is broken.
so its literally a case of hijackin the ignition barrel electrics.:)
Ahh I see. About time I have a perv of Haynes electronic section me thinks... :drool:
I've never touched the electronics systems other than repairing them with a soldering iron, so I'm a bit nervous about it but to be honest with you, it's too cool! :lol:
Thanks. I'll have a look at the barrel over my half-term. :)
Just need to mention, its a panel and has an ignition switch on it too.... will I need to do anything different?
linky..............?
Ok, it's on my PC so I have to upload it to the photobucket first......
......and here you are;
Aluminium panel with carbon Fibre effect finish. LED toggle switch with doomsday cover, engine start push button and 3 On/Off toggle switches. Wiring and relay included.
