Vsc , Tc And Check Eng Light On
rob virgo
Hi all ,
I have got an 04 tsprit d4d and have got the vsc,tc and check eng light on recently.Has anyone seen this issue and if so whats the cause.
Presume its a sensor or the like,tried disconnecting Battery to check if it was spurious but it returned....
thks for looking
rob v
Happened to me several times in an Avensis Tspirit, turned out to be an oxygen sensor and supermarket petrol lit it up every time , took me a few weeks to realise what it was and a few visits to Mr T , had a new one fitted and as soon as I filled up at a supermarket , Bingo ! finally rectified it by removing the cap on the oxy sensor and replacing it ? seems to reset it somehow , worth a try ! ;)
Hi all ,
Presume its a sensor or the like,tried disconnecting battery to check if it was spurious but it returned....
thks for looking
rob v
look at the speed sensors on the wheels
Take it to the nearest dealer and get the fault codes read. Otherwise it's like lookin a needle in a hay stack.
