Power Steering Reservoir Location
davegooner7
can any one tell me were is the power steering reservoir on 1.8 2004 avensis i have looked every were in the engine bay and cant find it
dave
Dave
If you are stood at the front of the car look under the plastic cover to your left (Drivers side), behind the washer bottle.To have a proper look at the level I would whip the cover off.
Andy
dave
There isn't one. It's electric power steering.
dave
yes correct
cheers/Igor
dave
yes correct
cheers/Igor
so is there no fluid to check
dave
yes correct
cheers/Igor
Don't know about the Avensis electric power steering but usually the pump is electric and there is still a reservoir for hydraulic fluid mounted directly on the steering rack. This is usually down the back of the engine, low down on the bulkhead.
The Avensis may be totally different but if no one tells you otherwise it may be worth a look.
