Ae82 Gt Donor Car
cut1664
hi there guy's,just want to pick somebody's brains about my ae82 gt.i was wondering how difficult it would be to transfer all the running gear,rear axle,dash and wiring from my gt to a standard 1.3 ae82 Shell as my car is beyond repair with rot to the Shell.i have found a very clean example of a 1.3 and was hoping to use it as a donor car.any help on this would be much appretiated.cheers regards chris.
hi, its not that difficult, altho one of the mounts will need welding , fuel tank will need changing the antiroll bar and steering rack, rear hubs unless you wanna use drums, steering column so you can use tilt on the steering, otherwise pretty much simple.
