Tranny Swap Suggestions?
corollaxae92
Hey there Corolla and Toyota Fans and others! I was wondering What kind of Tranny will bolt up to the 16valve EFI? I'm not too sure any suggestion be great tahnk you ^^
- Wa
afaik the 4-speed from the boxy starlet MIGHT fit...
the 5-speed from the ee90 and ee101 corolla's will fit, as will the 6-speed e11 G6 (NOT g6r)
and the LSD-equipped glanza turbo gearbox will also fit, 5-speed) Note:this was an OPTION on the glanza's, and the driveshafts are needed too as the driver-side drive is shorter than the non-lsd corolla
Hope this helps :)
Hope this helps :)
THankZ Man I appreciate it!!
