Both Stop/break Lights Suddenly Not Working
Zan
Both of my corolla's break lights suddenly have stopped working however central break light in the rear window and both tail lights work fine.
Is this problem fixable without taking it to the garage? I have 2002 1.6 T-Spirit hatchback.
Many thanks
You could check the fusebox to see if it's blown, it's located behind the glovebox need to take it out, then look upwards inside the dashboard to find it.
Bing
:thumbsup:
Thanks for the reply. Just checked the fusebox and it seemed fine. Also central break light up in the rear window works well, could there be a problem with the wiring?
Sounds like 2 x bulbs to me, its the first/cheapest place to look, happened on Mrs Kingo's Yaris once, just bad luck they went at the same time
Kingo :thumbsup:
