2Zz Lift Bolts
Corolla Glynn
Evening boys and girls,
Used to be on the forum in 2006 as tsport kid but could I remember the password?
Anyway bought my second tsport last month after owning a leon tdi cupra with 210hp and 400ftlb which I had spent 10k on!
Replaced the lift bolts at the weekend, my car is 05 fl with 39.5k on it.
Must say after so much speculation about lift bolts that yeah mine had wear on them but not at the point where thay looked like they may fail. But to drag this topic up again, I believe they are worth replacing every 20k as the lift is just that little bit smoother and stronger.Easy job too, did mine within half an hour of stopping the car, good idea to let it cool down though!
Anybody got any advice on patience!
Glynn
Mate have you got a part number for these bolts ?
Sure have obviously 2 required 90105-06293 retail at £1.25 the pair inc vat
Glynn
Thank you mate
Now just got to find the how to guide
Thank you mate
Getting the rocker cover off is the hardest part and thats simple really.
Dont overtighten the rocker cover bolts or the lift bolts when you put it all back together.
Glynn
use a torque wrench to tighten the lift bolts - you only tighten to 7.5nm which would be easy to strech the threads without one. the revised bolts do still wear ever so slightly but nothing to worry sbout - 40 - 50k change just to be sure. check the cam for wear while your their too.
Any how guides I can look up ?
newcelica.org - and theirs one on here from years ago but the search facility seems w5nk now.
A couple of links that you may find of use in this post found in another lift bolt related thread.
Thank you men, sorry to of hijacked your thread Glynn
