Corolla E11, Wiring Problems
cmi
Hello.
I will try to explain my problem. i had a diagosis on my car today, because it wont work properly, it dies when i push in the clutch and let it fall on rpm. Det diagnosis shows that it is five errors, and when we look up the error codes the wiring system is reapeted on every one of them.... Any ideas??Bad grounding some place??
I'm still learning about Corollas but on my previous car(Nissan Primera)the fault that caused the same symptoms that you have was down to a faulty maf sensor.Do Corollas suffer in the same way?
Might be, i just think it is strange that the wiring system is listed up on all 5 errors! :S
