Key And Remote Locking Fob Help
shanning
I today was in receipt of a corolla 1.3 gs 1998 model. Unfortunately it came with only one key and one remote locking fob. I can get another fob off of eBay but am concerned about the programming of it. Am i best going to a toyota dealer or should i save some desperately needed pennies. If it's something i can do myself then i am more than happy to try. But also how would i go about finding out how to programme it????
Sorry what a load of waffle lol
I did this on mine with a fob bought on eBay and it worked fine
1. Get in drivers seat leaving door opened and key NOT in ignition
2. Insert key into ignition and remove
3. Press the door lock - unlock button (on door panel switch gear) 5 times (40 seconds max)
4. Close drivers door then open it
5. Press lock - unlock button 5 times again
6. Insert key into ignition
7. Turn ignition key from 'lock' to 'on' ONCE (no more as you can wipe all codes)
8. Remove key from ignition
9. The central locking should now start locking and unlocking on its own
10. Within 20 seconds press and hold the remote 'lock' switch for more than 1 second
11. Once more if the receiver has received the signal the door locks should start operating on own
12. Close drivers door and open it
13 Press and hold the 'lock' button on remote for more than 1 second.
14 the door locks should once more cycle lock to unlock on own, once this time
15. If another transmitter need tuning carry out steps 10- 15 with next transmitter.
Make sure that the interior light comes on with the door open or it will not work.
