Radio Not Working
Ivor
Hi have had this problem for a while, the radio, interior light, luggage comp light and probably a few more are not working tried changing fuse but keeps blowing, there must be a fault with the wiring, has anyone else had this problem if so can you advise Thanks
You seem to have alot of things attached to this one fuse, how big is it?
How does it blow as well, what things do you have on that caused this, could give some idea of what might be causing it.
Only to be sure, would be to route the cable to see what's attached to it and check each point along it, and making sure nothing is making it earth too.
