Cruise Control Down Steep Inclines
BlueValour
The cruise control works just fine is normal driving with the car accelerating and braking as necessary to maintain the set speed. However, going down particularly steep hills results in the car progressively increasing in speed due to insufficient braking. Is there a known limit to the steepness of inclines for which the cruise control is designed to function?
Have you looked in the Owner's Manual? It is mentioned in the USA 2007 OM, it is a bit vague on steepness (and I'm far too lazy to get dressed and go out to the car to thumb through my paper copy of the OM):
"Your cruising speed can be maintained up
or down grades within the limits of hybrid
system performance, although a slight
speed change may occur when driving up
or down the grades. On steeper hills, a
greater speed change will occur so it is
better to drive without the cruise control."
CAUTION
D To help maintain maximum control
of your vehicle, do not use the
cruise control when driving in
heavy or varying traffic, or on slip-
pery (rainy, icy or snow ­covered) or
winding roads.
D Avoid vehicle speed increases when
driving downhill. If the vehicle
speed is too fast in relation to the
cruise control set speed, cancel the
cruise control then shift the shift
lever to "B" position to use engine
braking to slow down.
AFAIK the Cruise control is not adaptive, i.e. it doesn't brake to slow the car down. It just lets off the accelleration, which results in regenerative braking to the same degree as when you take your foot off in non-cruise mode, but no friction braking occurs. Putting it in "B" would add engine braking to the deccelleration phase.
