Leveled !
kav
Morning all ! B)
One common problem in various tasks performed to our cars,is, that often we
have to level the car.
e.g. for an oil change, gear oil change, etc. :arrow:
Our garage should be leveled when it was built, but we do not all own/have a garage,
and often we have to repair something in a ramp or elsewhere.
Leveling the car, might need maneuvring, move forward, reverse, place a piece of wooden
board under the tyre, etc.
Even if we just want to check the engine oil level at a glance, car should not be uphill.
So, we need to buy a spirit level with bubble, a piece of teflon + some screws.
:excl: Locate a space in your car, where a square piece of our teflon will be placed.
The case of Battery is usually the best place, as it is already levelled + easy to see...after ! :eek:
Measure, how much space you need. There must be enough space for the spirit level + mounting screws !
Cut the square you need + with a file sharpen the edges.
Also clean the surface....
:excl: A kitchen bench is our place to work now.
Place the teflon on it + place the spirit level on it. Should be all leveled. :artist:
If not, then it's wrong. Make sure your piece of teflon is clean....the bench too!
Screw the level to the teflon tight. A tiny drop of glue is welcome.
Cut the salients + straigten with the file, carefully.
1/2 job done. :clap:
Moving at the car, we need to level the whole vehicle. A well-known leveled place to all,
is a....workshop! :death::death:
Or a place we surely know it's levelled. Ok, there no need to drive mad with accuracy... :drunk:
Check tyres pressure ! No need to say why... :eek:
We put the teflon to it's place + mark the point. All leveled now.
Aygo's Battery case is common for petrol + diesel engine, so there already exists a M6 hole.
You might need to drill yours....
Now we need to drill the teflon. One 5,5mm hole will do the job.
Take a M6 screw + washers + tighten everything. :group-cuddles:
Do not overtight + recheck aaaaaaaaat the...workshop. All leveled ? :eek:
1/2 + 1/2 = 1 ! :thumbsup:
Done !
ps. 1000 words = 1 picture. :driving:
:Jumpy::Jumpy:
2 yrs now...
don't look at the bubble, photos are taken after the job! :P
Cheers ! :yahoo::yahoo:
one more thing to do once you are here, is a piece of rubber under the..battery.
Isolates several vibrations from engine. ;)
Fitted... :eek:
cheers !
