Corolla T Sport
robtheman
hello guys
i have got a 2004 t sport and its done 107k miles
i have had to reaplce my front 2 wheel bearings which is fine due tot he mielage but ive also had to replace the passenger "flange" (not being rude haha)
any ideas how much a flange will set me back????
cheer guys
rob
Wtf is a passenger flange ? Is it between the suspenion legs lool
Good one :lol:
Didn't leave your missus in the passenger seat did you?
lol
i now found out that it is actually called "front axle hub"
still none the wiser with costs though!
any ideas... ??
I can't help with the cost sorry - but I'm interested to know why you need to change the hub? Were there any specific symptoms? I only ask because I'm familiar with worn wheel bearing symptoms but have no idea what happens when a hub needs changing!
Gareth
If the hub needs changing it could be because the bearing has seized and was spinning in the hub, so the new bearing will not be a tight fit when it is fitted.
Last winter toyota quoted me around £150 for one (if my memory is correct!)
