Brake Oil, Gear Box Oil, Clutch
kintung01
Hi all,
My tsport is due for service soon, and i would like to get the brake oil and gear box oil.
What grade i need for gear box oil and brake oil? and how much i need
is it 75-90 for gearbox oil? also should i change the gear box oil when i change the clutch?
Toyota told me that i only need to change the coolant at 100,000 miles, is this true?
Thanks for the advice
Hi all,
yep 75-90, theres a very good guide on how to do it on here somewhere. the manual states 2.3l, but mine used just under 2l
Brake fluid im 99% sure its dot5, but i'd wait for someone else to confirm before you go ahead and change it
if its pink its every 100,000 miles
Brake fluid is 5.1 nowadays, not 5 - it destroys seals apparently.
Did mine the other day with a litre bottle from Halfords and a simple ball bearing bleed kit attached to a fruit juice bottle :thumbsup:
