Engine Oil Change
paul121
Hi can anyone tell me if its difficult to change oil and filter on 53 plate d4d. is oil filter easy to access and remove or will just changing oil be enough
Hi Paul,
Not difficult see pinned section above 'Technical information' for method and tools required. Always renew filter to get rid of the debris and muck, if you don't your new oil is contaminated as soon as you start the engine.
John
