Jdm Cold Ram Air Induction Intake Filter Kit
garyg47612
Just bought a jdm cold ram air inductionr induction intake filter kit for my 2002 vvti 1.8 140bhp celica,i can remove the stock box etc but when it comes to connecting the blue pipe supplied with the kit to the bottom of the vsv for canister closed valve iam in diffs as icant find it anywhere,i see the evap which goes with the new kit and the other vacumn on bottom of stock box which is not used with this kit but just cant see where the third vacumn is,please can anyone help,also are these kits of any benefit?
The ram effect just doesn't come into play unless you are doing around 100 mph or more.
Plus any inlet temperature benefits are lost after travelling around a quarter mile or so.
Some people argue that cooler air allows more oxygen into the engine to aid combustion but as soon as any of the engine sensors detect this then the ECU may then adjust to compensate.
The only sure method of detecting any benefit is by doing comparative tests on a dyno machine and even at that it just doesn't reflect real conditions.
