Tsport Kit Tte Compressor With Many Problems
juan-1
Hi all.
first say sorry for my English, I'm Juan from Spain
I finally decided to launch and mount the TTE kit, also with some more goodies.
Bilstein
Brembo kit
To say that we are distributors of EBC in Spain and Brembo discs were not able todissipate the temperature rise of the orangestuff, the rims reached very high temperatures.
It was decided to switch to a kit Ksport
The steel disks is worse but for now hold the temperature 1000 ° the orangestuff.
It also adds a TRD limited slip and c-one (Kaaz) trasmision closed end
This car is for the use and promotion circuit, it is very funny
But as you know it's hot in Spain and the car heats water ...
so we installed a radiator Mishimoto
do you see diferences?
Problem solved.
Now the other problem we have is that the car has no ic and 20 degrees of temperatureare able to lose 30hp
decided to put a Mishimoto ic
(yes, we are also distributors for Spain)
Although we have not finished installing it is difficult
this is the part of the problems, because with the installation of the ic I would like to put asmaller pulley.
I found this:
http://www.pulleybros.com.au/page8.php
I have seen that our compressor is the same as the SC12, but not if it is compatible
Has anyone tried it?
work?
a lot of money to investigate ..
I have wanted to finish the car and how far it can go ..
thats a really good build you have there juan-1 , keep this updated :)
tell me was the MISHIMOTO radiator a straight fit ?
thanks scott
Hey.
The radiator fits perfectly.
Only with the compressor must be removed fan bracket, so you have to buy theMishimoto fan.
Greatly reduced temperature.
regards
You guys are crazy machines to apply these compressor
Hi im thinking to replace my radiator what is the size of the mishimoto fan. it is just a straight fit in? and simple to replace by myself?
Hey.
regards
Hi!
yes.fit perfect,for the corolla TS
But the mishimoto radiator is double core in comparation with oem
For the corolla TTE compresor need a 16" fan and the kit mount.
with this fit perfect.
If you have another question,ask me.
