Air Conditioner Not Cooling
Coriolis
I have a Corolla VVT-i (2005 model).
It's no longer blowing out cold air - the air temp seems to be the same as when the air con is turned off. The green light comes on, but it's not indicating a fault.
There's also no water coming out of the bottom of the car after using the air con.
I did notice a few weeks ago that the vents were blowing out some condensation for a few minutes, but the problem with it not cooling started even before that and it was a very humid day when the condensation was visible.
Any ideas please on a possible fix?
check to see if the compressor is working ok.
If you can, try find somebody with an air-con gauge, connect it on see you can see if it has pressure, if not you can get top-up cans from Halfords for air-con, so get a can and inject it in, see if that helps.
otherwise, it could be a case of get toyota garage to give it a check over.
Thanks - afraid I don't know anyone with an air-con gauge, so I guess it's a garage job.
Or is there anything else that I can check?
My advice is not to use a top-up can.
The amount of refrigerant in the system is measured by weight NOT by pressure. Incorrect amounts of refrigerant can lead to expensive damage.
