Sign in to follow this
doctorc
Toyota Diesel Injection Cleaner...should I Use It ?
Hi All,
I have a 350ml bottle of Toyota Diesel injection cleaner, but not sure if i need it. I have an Avensis D4D 2.2 T180 2006, which i have had for about 3 years and never added any cleaner. I am guessing the previous owner may not have either unless the dealer added it in services.
If i dont have any obvious performance issues is it something i should add regularly when filling up to clean injectors and do i add the whole bottle when i fill up ?
thanks
Dave
Share this post
Link to post
It will do more GOOD than harm, modern supermarket diesels have less additives, so there is a danger the injectors can get gummed up, it wont harm the car at all
Kingo :thumbsup:
Share this post
Link to post
Yep as Kingo has said it will do more good than harm and would use that particular cleaner at least once a year.
I use another type of additive at every fill and use Shell V-Power :)
Share this post
Link to post
thanks both. I guess the next question is do i add the whole 350ml bottle before i next fill up or just part of the bottle ?
Share this post
Link to post
What does the bottle say?... Just bank it in tank and see what difference it makes :eat:
Share this post
Link to post
Is it a genuine Toyota injector cleaner? Personally I wouldn't unless its giving bother - use good quality fuel and change the filters regularly with genuine parts and you shouldn't have a problem.
Share this post
Link to post
It won't do any harm ^^^^^^^^^^^^^^^^^^^^^^^^^
Bang it in...
Share this post
Link to post
Its only a mild cleaner and was on ebay a while back for £5, the bottle to a full tank.
Just `Bang it in` as my mate Mistermena says,
Share this post
Link to post
It is a genuine Toyota cleaner so will add whole bottle to next fill up and let you all know how it goes. thanks all !
Share this post
Link to post
