Clutch Pedal Switch
ALake
I was looking at my clutch pedal tonight (as you do!) when I was trying to see where my slight squeak was coming from - and I noticed the pedal has a sort of 'tang' on the side, which is in line with a bracket with a hole in it. It looks very much like a switch or something goes in there - presumably to detect when the clutch pedal is depressed.
Question is - what RAV4 actually have a switch in the place? I'm assuming mine isn't missing and was never there anyway, but what models have them? (Mine is a 2008 2.0 VVTI XTR)
On some Toyotas (eg the Auris) one has to depress the clutch in order to start the engine - a system which is commonplace in the US and would presumably be fitted to US market Rav 4's.
Do the U.S. get manual RAVs? I thought they'd all be autos over there.
Models fitted with keyless entry/start have a clutch pedal switch as the pedal has to be depressed before the car will start.
Ahh that explains it. I forgot some RAVs have the button start!
Rav's which are fitted with cruise control usually have a clutch switch fitted - to disable cruise control when the clutch pedal is pressed.
John
Mine does have cruise control, and it appears to be working. Maybe it works on the brake pedal in 'newer' cars?
