02/lambda Sensors.
dodgy_damo
2 hours ago, Luv said:
I have a 2005 auto T spirit 2.0L avensis. Mice managed to enter the engine area and chewed half of the 4 wires to the 1st coil pack near the oil tank cover. If i get a replacement wire with the connector do the colours matter when joining it with the half left in the car?
Yes the wires must be connected in the correct order and they are colour coded for a reason! I recently replaced a broken coil pack plug -
Use the other coil packs for reference.
Years ago I repaired damaged wires of an O2 sensor and had to repair a couple of broken cables.
If the wires are chewed through you can rejoin them using waterproof heat shrink butt solder connectors
images?q=tbn%3AANd9GcRBjrnTZmgDlYv0CiTWcc-1MiM3nGd8Lp4d540zDQfwgQeJoIBEW489-Lk82A&usqp=CAc
They may not be good if near heat sources!
