Mirrorlink 1.0 To 1.1 Upgrade
mfraile
On 30/03/2017 at 7:51 PM, Devon Aygo said:
iPhones require a specific accessory lead to work with the mirror link, android phones can use their standard USB leads
Can you clarify how this works? Is it possible to use Mirrorlink with an iPhone to Touch and Go 2?
The download to 804 is down. Everyone could share the file?  Thanks.
Hi Chris70,
I am putting two files:
1 - XTOUCH + RC1 + software + update; and
(https://mega.nz/#!RZFXjLLY!XJu50AqvAevb09VVmKdssaX1-zJVyZAp3_8fsC8vYoM)
2 - 13TPDAEU-EA01_0003 (840 version)
(https://mega.nz/#!0M8kzDBS!t858ooC_Ft6U6jk9A3cyT80IHVEON0eqUB3e95AO_BM)
I believe that the file "XTOUCH + RC1 + software + update" is complete and enough to update the system to version 804. I think the file "13TPDAEU-EA01_0003 (840 version)" is just the firmware.
Greetings,
Clovis
Hi Clovis
I’ve just tried your link to download the version 13TPDAEU-EA01_000(840 version) but it needs a key.  Can you help?   I have 820 at the moment is this an improvement?
regards
chris
17 hours ago, Chrisjt said:
Hi Clovis
regards
chris
Hi Chris,
It's strange, because the links already have the keys. But alright... Here are the keys:
XTOUCH+RC1+software+update.zip
Key = !XJu50AqvAevb09VVmKdssaX1-zJVyZAp3_8fsC8vYoM
13TPDAEU-EA01_0003 (840 version).zip
Key = !t858ooC_Ft6U6jk9A3cyT80IHVEON0eqUB3e95AO_BM
Regards,
CYK
4 hours ago, CYK said:
Hi Chris,
Regards,
CYK
Thanks for that, it asked for key again but when I input the key you provided it downloaded ok
thanks again
  • 3 months later...
On 5/3/2017 at 10:40 PM, Devon Aygo said:
Download the file and open, double click on the .exe file and run the extraction ( don't use windows to extract ) extract to the root of empty USB, do not alter the file. Use the PDF to complete the update on your head unit
13TPDAEU-EA01_0003.zip
Hi Devon,
Downloaded the zip file. I extracted the KIWI file and followed all the steps.
The head unit shows that 1 of 1 files is been installed arround 35% the headunit shut off and goes back on and then does nothing.
When i check the system it shows that the old Audio 0820 is still in place. Tried doing it severall times.
Tried a different USB and Tried Downloading the file again and still nothing.
Any Advice???
  • 4 months later...
Hello, Can someone send me the update file 13TPDAEU-EA01_0003.zip. Thank you.
See my post above for the update 13TPDAEU-EA01_0003.zip:
Regards,
CYK
Hi folks,
Today I've bought a Toyota Aygo from 2014 which is currently on 705.
I've followed all steps, got both 810 and 840 on usb drives but my car doesnt seem to recognize any of the usb drives (I have 3 of them)
I don't get any pop up at all after i insert the usb drive when it's on software update mode.
I tried both FAT32 and NTFS formats, both to no avail. The usb drives are 4-16-32GB ones.
Does anyone have any idea?
TIA
As you are on version 0705 you MUST update to version 0810 first you can then jump versions upto the latest of 0850, you must also ensure only the correct file is on the USB, see:
I was already aware of that, I happened to find out that my multimediasystem does not recognize any usb stick at all.
I even inserted a usb stick with music on it and the usb stick is greyed out on the media menu.
I am guessing its a faulty or lose cable (it does charge my phone when I connect it though). Really strange.
Do you have any idea how I can remove the X touch system from the dashboard? I took the plastic piece off but I dont see any screws holding the multimediasystem in place.
Thanks!
Thanks!
https://www.toyota-tech.eu/aimuploads/0336742c-e173-406b-a612-fe19c04843bd/Aygo_X_NAV_RHD_PZ41C_90331_00_AIM_003_763_1.pdf
Good evening Devon
In your Post you talk about the firmware version 850
Where is it possible to find this version?
No advance thank you very much for your information and information
Best regards
Roger for Paris
What is the latest SW release? Can someone provide link? I have 804
  • 6 months later...
Hi folks,
I've updated my Aygo 2014 to v.0840. Is this the latest version?
Latest version is 850.
Thank you, have you got a link for the fkle update?
Posting here because i'm totally and absolutely confused there.
I'm thinking by buying a second hand aygo 2 (2015 1.0). The current owner uses her iPhone for GPS. But I own a pixel 3a. From the last post, I understand i should be able to update to get android auto compatibility if not already there ?
Really hope someone can provide the 850 firmware here.
Android auto is only available on post 2018 models with third "Talk" switch on the audio unit, there are no updates available for earlier models other than installing a headunit from a later car
Version 0850 HERE please follow the steps below paying special attention to step VII:
Table 1. Follow below steps to perform the actual software-update :
1. Prepare a USB-stick to update the X-Touch Display-unit to software-version 0850.
  1. PLEASE TAKE A NEW, EMPTY OR FORMATTED USB-STICK WHICH MEETS FOLLOWING MINIMUM REQUIREMENTS :
    - the used USB-stick must not have a HUB-function (it should not contain a card slot or another USB-device insertion slot).
    - the used USB-stick should not have a security function (encryption, ...).
    - used file system on the USB-stick should be FAT32.
    - USB-stick capacity/size should be more than 1GB.
    - used USB-stick should not carry write-protection.
    - USB-standard = USB 2.0
    - the USB-stick preferably has a LED-indicator lamp to see "access" status.
  2. Important
    If the USB-stick already contains previous data or files, please format the USB-stick using FAT32 file system.
  3. DOWNLOAD THE "0850" SOFTWARE VERSION UPDATE FILE (.KWI-FILE) ONTO YOUR LOCAL PC HARD-DRIVE
  4. COPY THE DOWNLOADED .KWI-FILE FROM YOUR LOCAL PC HARD-DRIVE LOCATION TO THE EMPTIED USB)STICK.
    Important
    i. Don't save other files onto the USB-stick together with the .kwi-file.
    ii. Do not change or rename the .kwi-file.
    iii. Don't put the .kwi-file inside a folder on the USB-stick.
  5. PLEASE LABEL AND NAME THE USB-STICK FOR FURTHER LATER USAGE. E.G. "AYGO X-TOUCH 0850"
At this point, the USB-stick is ready to proceed with the actual software reprogramming --> see "2. Update the X-Touch Display-unit to software-version 0850"
STEP no.
ACTION
DETAIL
I
switch vehicle ACC or I/G ON (depending on vehicle status or location)
II
(If "Menu” screen is not displayed, press lower knob to access "Menu” screen.)
Press "SETUP" to enter “Setup” screen.
III
Press "General" icon
IV
Press "Down" arrow button
V
Press "Software update"
VI
Press "Update"
VII
- If current version shows :"0840","0830","0820","0810" --> proceed STEP VIII
- If current version shows "0705", please apply TSB no. BE-0015T-0217
VIII
Insert the prepared USB flash drive in the vehicle's USB - connection port.
--> "New software was found." pop-up will be displayed
IX
Check if the correct software-version "0850" is displayed under “New”.
If so, push “Update software”-button to continue.
X
Press “Yes” on the Software-update confirmation screen.
XI
Wait for the software-update to finish completely.
(This should only take a few minutes)
Important
・Do NOT turn OFF the engine or ACC before the software-update process has completely finished.
・Do NOT remove the USB-stick from the vehicle USB port
XII
When the software-update has finished completely, the "Ready with update" screen is shown.
XIII
- Switch ACC or I/G OFF
- Remove USB-stick safely from vehicle USB port
(Switch ACC or I/G back ON)
