water in car boot Toyota auris 1.4 d4d diesel
mashdee
Hi guys,
I have recently bought Toyota auris 1.4 d4d diesel 2007 reg..  I am just wondering if anyone has same problem that water is coming in car boot where spare tyre is placed? can any one tell me what is the solution of it to prevent water coming in, i got doubt the water is coming from bottom, normally i cant see any hole!!
thanks
Welcome to Toyota Owners Club.
Post moved from the Auris Club to the Auris Club.
Water could be ingressing via the vents behind the bumper or via the rear light cluster/s. Both instances are due to seals perishing. Can be cured by applying a sealant to the affected area. See -
thanks frosty.did you mean to say that i need to block vents? and .Is there any kind of special sealant pls?
The vents behind the bumper have foam seals around them.  When I had a similar problem with an Avensis I removed the vents and used foam draught excluder to 'thicken' the seals and re-fitted them.  Problem solved.
Sealant can be used in place of the perished seals.
