2015 Yaris rear bumper
Barnman
On our Yaris rear bumper it has come unclipped on the right rear just below the rear lamp assembly.
This is leaving a gap of 4-5mm between bumper and rear wing. It will not simply push back together :rolleyes:
Looks to be a common fault. My daughter has an identical model and her's has gone the same way.
So my question is twofold:
1. anyone else having this problem
2. how do you fix the problem (please don't second guess it!)
Dave
It will have had a little bump on that corner and broken the plastic bracket that holds the bumper to the body, take the bumper off, replace the bracket, check for other damage, if all OK you should be able to put the bumper back on and good to go
Kingo :thumbsup:
Did you find a resolution to this fault Dave ?
I purchased a new Yaris last year, and it has not been involved in any accident. But I am having the same fault, I am now passed 10 attempts of it being fixed and the bumper has even been replaced but still the fault occurs. The repairs have been carried out by the Toyota dealership, a Toyota repair centre and even a Toyota field specialist, but the repair still fails.
The repairs can last from 24 hours to several weeks and it can even fail when the car hasn't moved for days. Now Toyota say it's caused by "outside influence"even though they have no evidence of this and will not repair again, even though it's their repair that keeps failing. They have only given a reason for this failure once and it was that a clip/tab was pointing the wrong way, they have no other explanation for the other times. It seems they can use this excuse of "outside influence" when they choose to, so they don't have to deal with the fault.
Cheers, John
If it's less than a year old and they've had three or more attempts to fix the fault, then I understand you've very good grounds to reject the car.
You may care to consult citizens advice, or confront them with this.
do you mean the top corner at the most forward point of the bumper on the sides ? if so they move in and out about 1/2 inch, i thought it was strange but i tested another car while i was buying mine and it did the same, they are secure though
It is the o/s top corner exactly the same as Barnmans post described, but on occasion as with this time the n/s corner is now not laying flat with the rest of the car. As with secure well toyota say the couldn't guarantee it wouldn't get worse if left or even fall of completely.
As for rejecting the car well I am still looking into what options I have available. The consumer rights act doesn't seem to be worth the paper it's written on, and because last time it was fixed they said it was an "outside influence" (never been said or found to be before) and again this time there was no evidence available apart from one persons opinion, who's repair failed in 24 hours. Seems if they say this it's an easy hands washed of problem. I hoped at some point they would have fixed it properly because I like the car or they would have given me other options. So still looking into other advice and what other avenues available before looking at the cost of legal action and the gamble that is.
 Cheers, John
At the end of the day, your contract is with the dealer who supplied the car, not the manufacturer. So any legal action would be between the dealer and yourself.
Why not make an appointment to go in and see the Dealer Principle/General Manager? Tell him how unhappy with the situation you find yourself in. Nobody should have to think of going the legal route to sort out something that should be easy to fix. Often the Principle/manager will be completely unaware of customer issues like this and will do their best to get it sorted out, why would'nt they want to? They want you to go back and buy again, not simply fob you off
Kingo :thumbsup:
So I took the bumper and O/S/R lamp unit off this weekend to reveal the plastic brackets.
They are OK with no evidence of damage :blush:
What is evident is the latching system used between the bumper edge on the bracket is very week.
In particular the small tags on the top edge of the bumper - the plastic is like putty!
So after cleaning up the tags of the burrs it rematched OK.
But when giving the bumper a tug they came unlatched :rolleyes:
My conclusion is that the plastic used is not fit for purpose
Don't forget that my daughters identical car and other members cars have gone the same way
Are Toyota now admitting that there is a problem?
Cheers, John
Hi John,
Look like you have tried to have this fixed more than I have matey.....
8 minutes ago, Barnman said:
My conclusion is that the plastic used is not fit for purpose?
That is just your opinion.
Contact Toyota and ask the question.
Yep that's my opinion matey. The plastic is like putty and seems to let go!
(Retired Traffic Cop/Vehicle Examiner :cool:)
Have you experienced similar problems with these models?
Do we have someone in Toyota where we can ask simple questions like this?
Dave
One can contact Toyota either through their website (www.toyota.co.uk) or Toyota GB Blog (blog.Toyota.co.uk)
  • 2 years later...
Dave yeah mine as the same problem, noticed it shortly after purchase so went back to the dealer who advised me to take it to their bodyshop, guy assured me it wouldn't fall offf and said the clips were extremly expensive making it a very costly job, felt i had no choice but to leave alone but not happy with it, just wish i'd have noticed it before buying the car, one exactly the same parked up on the car park where i work and thinking of leaving a note on asking if they were aware of it and if they had try to get anything done about it, i think its a common fault and feel the Toyota should recall these cars and repair, ive checked other makes and they're all in tact
It isn't a safety issue, so won't fall under the criteria of the DVSA recall system.
I had a similar problem but it was self inflicted. I reversed into a plantpot - don't ask!
The right side of the bumper moulding came away from the mounting on the rear quarter. It would not refix. I found that the plastic bracket, that is fixed to the body and into which the bumper clips, was deformed. As a result it could not hold the "nubs" on the bumper. If all the fixing "nubs" on the bumper are in place, not broken or bent that could be all it requires - a new fixing on the car quarter. It is fairly easy to replace. Some pushpins need removing underneath, one bolt at the bottom of the hatch opening allowing the bumper to be pulled away sufficiently to access the one securing bolt and removal of the fixing. Refitting is, as they say, a reversal, making sure all the clips line up before pushing them home. I think the whole job took about 20 minutes.
Why the bodyshop have said it's expensive, no idea. I purchase the plastic bracket from Parts King. If the fixings on the bumper are broken/damaged, then yes it will be expensive.
Its an obvious fault and unsightly too but getting anything done these days "after a sale" is never easy and it seems the more expensive the item the harder it is
it was the dealers bodyshop and he quoted around £750 for backand front
it was the dealership bodyshop and he quoted me around £750 for rear and front bumber
  • 2 years later...
