Sunroof leaking
Puffinstuff
Hi folks,
Need some advice.  I've got a 2001 verso and have started noticing water ingress into the interior.  Coming in where the sunroof operating mechanism sits under rearview mirror and over the driver overhead panel.  I understand that sometimes the drain holes can get blocked.  The difficulty is that I can't find them when I look.  Is anyone able to share an image of their location or give advice for other possible reasons for the leak if not this.
In anticipation
Jim
Just be aware that the original (Corolla) Verso was only exported to Europe between 2001 and 2003, before being replaced by the European built Corolla Verso in 2004.(which is a different model, body, etc).
