Fuse for the Touch 2 System
shaks08
That's great, thanks flash. I'll just confirm everything with the guys fitting it and order this kit. Hopefully everything goes smoothly
On 3/26/2023 at 2:34 PM, flash22 said:
The black side pieces are too far back, they should be flush with the screen
it's the wrong fascia for a 2016 the one you have looks like the 09-2011 one
CT23TY90
CTSTY015.2 (inc camera adapter)
Just to update, I've got the cable kit but struggling to find the fascia, @flash22any chance where I could get hold of one. Online sites state they have it in stock but when you ring them to confirm it's out of stock. I was waiting for the fascia for 2 weeks than I had to ring them to cancel the order after they couldn't give me a date when they will receive from factory. Same goes to all other tech shops in uk.
Drop connects2, an email, car audio direct have been very good over the years
https://www.ebay.co.uk/itm/353855587741
there are 3 different facias
09-11
11-15
15-18 CT23TY90
you may be able to use what you have if you mount the radio  with the factory brackets
I looked into the 'incartec' but it's a little misleading as states compatible from 2009 - 2011, than further down the listing it also states from 2009 - 2018, I've sent a message to eBay listing if they can confirm the stock availability. Last resort I will try what you suggested mounting the radio to factory brackets. Thanks for your help flash
