A/C blows very cold then warm. A/C blinks error 31 41.
TC9
Hi, my Estima 2003 A/C sometimes works and blows very cold, but stops working after 1 hour and A/C light blinks.  The built in A/C diagnostic shows error codes 31 and 41.  My mechanic says the A/C pressure is ok, no leaks and asked me to find a electrical diagram to help them diagnose the problem, but I don’t have this diagram.
I stopped using AUTO button and set temperature to COLDEST to eliminate some potential sensor issues.
I read it could be any of following?-electrical wire, relay, amplifier, sensors, servo motor, compressor clutch, belt etc?
Any suggestions on how to diagnose my A/C?
Does 2003 Estima Hybrid AHR10 use same A/C parts as Camry, RAV4 or Sienna?
Thank you
31 - Open or short in power source circuit in
air mix damper position sensor circuit.
41 - Air mix damper position sensor value
does not change even if air conditioner
amplifier assy operates air mix servo-
motor.
i would check the mix damper motor, remove it and make sure the flap moves it's the lower motor on the driver's side 87106-28120
