how simple is it to change headlamp bulbs on 2007 Estima?
David A. Blair
On 10/3/2023 at 3:49 PM, David A. Blair said:
Im at a loss figuring this out!
Hi David
I changed the side light bulb on my 2011 estima,
Under the wheel arch there's a panel that can be removed, once removed you can get to the lights ,you may be able to change it from there, but it's a bit tight
Hope this may help you
