Steam Clean
vmail
how much does it cost to get a car steam cleaned
some petrol cars may not be able to start up, how can I stop this from happening
leave the engine running.costs about as much as you put in the slot to steam clean it yourself..20p---------£3
and where would you find one of those machines?
no its just ideal that the engines ticking over as it will stay ticking over
what do you think happens if you hit a big puddle? :huh:
advice from me though is to cover an electrical areas with plastic bags as the pressure the steam is under can force it through seals and onto electrical gubbins if your unlucky!
even better take it to a proper valeter who will know what hes doing
Be careful, we just brought a Glanza turbo out of Japan and when they steam cleaned it the water got into the spark-plug tubes and shagged the plug leads, NZ$200 after a day of thinking we'd brought a dud when it started to run on only 3 cylinders!!
If you get it steam cleaned in the engine bay get the person that cleans it to blow out the sparkplug area with compressed air.
Then make sure the leads are dry at the bottom where they cover the plugs when you get the car home.
you can buy a pressure washer from bnq for under £ 30 , they work well too. :thumbsup:
