2016 Auris Infotainment screen differences
///MAZI
My wife has a 2016 Auris 1.4 D4D business edition, my uncle has the same car but his infotainment screen has a more modern look with
square window style icons. Is it possible to update ours??
https://mag.toyota.co.uk/toyota-touch-2-how-to-update-your-maps-and-software/
The ending says:
You can also update the software of your Toyota Touch 2 system following a similar process. You will not, however, require a 16-digit activation code for software updates. View available updates in the ‘Software Updates’ section of the MyToyota e-Store.
So check if there is any infotainment updates there.
Upgrades are done via usb.
Too bad it's not just as simple like for USA, enter VIN and check >> https://www.toyota.com/firmware-updates
It's still the touch 2 they went from buttons to a glass touch screen, not up on the Auris touch 2 versions, but there are High and Low versions
just examples
https://www.ebay.co.uk/itm/276159679760
https://www.ebay.co.uk/itm/355079182731
IIRC the issue swapping between the 2 is the reverse camera the early one uses 12v reverse signal and the newer ones use Can Bus some minor rewiring is also required
I don't think it's worth it over some fancy icons and sharp edges.
I mean if you were to upgrade to some 3rd party android, where you can install anything you want, but still keep most of the car functionality, then that's another story.
  • 4 weeks later...
Both are the later face lift systems with touch instead of physical buttons. Some have square window like icons and some have a more dated looking interface, not talking about the pre facelift system which had physical buttons
This
vs
This
Nobody have an answer for this?
Its a difference in software see HERE if you have a software version starting 4.#.# then you have MM13 software if it starts 6.#.# then its MM16 if you have a the latest maps/software installed ( latest being 6.22.0#) then you will get the later interface
I have version 6.xxx and the new layout is better. However the auto preference route (fast/short/ecological) not working anymore. I have to always clicked my choice
