Toyota Verso 2013 2.0d excel False alarm and BCM issues
moss007
Hello Folks,
I am new to this forum and I hope someone can help me. We have a weird issue with our beloved Verso. So, during the early hours of the morning whilst there was terrential rain the alarm started going off. I tried to unlock the car with the remote but the remote wouldn't work! I opened the door with the metal key and started the car,. The alarm stopped. Now, when i turned the car off, the climate control fan wouldn't turn off and the car wouldn't lock with the key. After few seconds, the alarm started making the noise again. I was quickly trying to stop the noise as it was waking up the entire street. I then opened the bonnet and disconnected the +ve from the Battery.
The next day i connected the Battery back and used my OBD2 connector to see if i can get any error codes. Please see the screenshots attached. Got U0100, U0142, U0155 errors. They all point towards the BCM.
Any idea what could have caused this and how to fix this issue? Does anyone know where the BCM is located and a part number for the BCM? I am thinking may be there is some rainwater causing this issue but I want to remove the BCM and see any evidence of water ingress.
Any help would be greatly appreciated.
U0100
Lost Communication With ECM/PCM "A
U0142
Lost Communication with Body Control Module "B"
U0155
Lost Communication with Instrument Panel Cluster (IPC) Control Module
There are only two systems that can simultaneously share those codes the AC control amplifier or Smart key Certification ECU and with the keys not functioning normally the Certification ECU is looking suspect.
The faults are all CAN BUS communication issues and over three systems like this there is likely a common connection/junction point at fault here perhaps water ingress to a connector or wire harness.
Unfortunately this is most likely going to require a dealer or auto electrician to pinpoint
Thank you so much for the reply. Do you know where the BCM located in this car?
Can someone recommend an electrician in Hertfordshire area?
