Water Ingress
Roker
I was vacuuming my Corolla Hybrid out and notice a wet patch on the passenger side near the seat . I think this is from the drainage from the wiper blade area because it looked creamy like the shampoo I used, it must have found its way under the carpet
I have only 30000 km up, I cannot believe the drain tube is blocked, Maybe I used too much water when washing. Has anyone else experienced this
I used to work at BMW water test unit at the Oxford plant and water under the carpets at the front was often a leaking front windscreen. There were other area's too like bulkhead welds and even water getting into wiring looms. Get it checked out soon. If you can feel water on top of the carpet that is coming from underneath it then that's a big leak somewhere.
