Bz4x 12 volt battery discharged
Edward cyclist.
I had a cycle accident on 06/01 2024 and fractured my hip so cannot drive yet. According to  the owners guide page 32 the 12 volt Battery should charge from the traction Battery which is 100%, this is not happening, I also have a solar trickle charger plugged in. Has anyone else experienced this problem?.
Edward.
it will only charge the Battery with the ignition on, a solar charger will not be enough
