Surging
stephenc
Car : SV21 Camry Auto
When I adjust the throttle position sensor correctly, I have noticed that the car surges when cruising to a stop and rpm reduces to about 1,000. As a temporary fix, I have adjusted the TPS so that the IDL points do not close. What causes the engine to surge when the contacts are closed. I have also turned the idle screw completely close, yet the engine seems to idle a touch above factory settings. I have also noticed a lack of power when accelerating from stationary. Once moving, the car has plenty of power. Any help would be much appreciated. Thanks.
