Cat` Question
avensis_man
Can somebody please tell me if the Catalic Converter on a Diesel is the same as a Cat` on a Petrol Engine car? :help:
Many Thanks
:thumbsup:
yes, they do the same job, reducing harmful hydrocarbons.
Granted diesel burns differently but it still needs a CAT like petrol cars to be within safe limits.
Thanks for your replys.......
i want to know if i can take a Cat of a Petrol engine and fit it to a diesel engine?...or are they different alltogether? :thumbsup:
cats are usually welded to the exhaust, the engines being different proberly causes them to have different exhausts. so initally i'd say no. but i stand to be corrected.
What year is your car?, I think the diesel Avensis has what is known as a 'close coupled' cat, ie, bolted directly on to the manifold, where the petrol models have an 'underfloor cat' ie, front pipe from manifold then inline cat bolted/sleeved in between that and the middle section. So no you can't I'm afraid ;)
A little more info on the car might shed a bit more light :thumbsup:
Hope that helps.....
