1995 Toyota Supra Speakers
daz364
hi guys im from the yaris fourums im after some Speakers for a toyota supra 1995 front door Speakers its an imported car they are about 12cm already will i get a 13 or what please help
Hey, I'm new to this forum,
but for this subject have a look at a post I made on "supraforums" a while ago and see if that helps, you can find it here http://www.supraforums.com/forum/showthread.php?t=286084
basically in summary you can fit 6.5" front door Speakers but you need a custom mounting bracket (which you can buy or make), the stock units are 4" (or oversized 4")
The rears are oversized 6.5" and are easy to replace...
hope that helps,
Louis
hi guys im from the yaris fourums im after some speakers for a toyota supra 1995 front door speakers its  an imported car they are about 12cm already will i get a 13 or what please help
Hi I had the same problem finding custom fit ones however when I removed them I found they were similar to a set of LO-Z cabinet Speakers, they are like a deformed tri angle shape they are the same impeadance (Ohms) and sound great top end
reply if you need some and I'll sort you out £125 for the set
