Gearbox Crunch
tinnyz
or will it be syncros...? it only crunches when changing down from third to second... do i need a whole new box, or does anyone thing the clutch replacement will fix this? thanks again
could be the sycrho in the box, my ae92 does the same thing going 3rd to second and from second to third, new clutch didn't fix it but i'll just keep using it till it goes bang
my gearbox in my 86 celica does exactly the same thing.. i was told that there maybe a loose/warn washer/baring (i dont knw exactly -it was brushed over in a conversation) in the gearbox itself. sorry im not much help i havnt yet found out if it can be fixed without a new gear box.
thanks for the info on changing the cluch. ill cross that off the prolly needs done list. :wacko:
Sounds like a synchro. Try changing the box oil incase it's just clogged and not moving fast enough on changes. They do stick.
Put a flush in and drive a bit then drain all the oil and even although it's a manual stick auto fluid in. Even a 50/50 blend will do but a 100% fill is fine (to the fill line).
I have the same problem on a 95 ST202 Celica I've just bought - it only crunches going into third or fourth when at the redline though - it's fine for normal driving. Bit annoying at times though. New clutch has just gone into it so I presume the gearbox oil would have been changed already??
yer accordin to my mechanic my 2nd syncro is fuct it dont like goin into second unless ur doin like 5ks an hour so like 2m in wherever yous r lol. i wouldnt go slamin it into second or whatever gear yours is.. apparently it will f**k ur gearbox dont quote me though
if its just a crunch d00d slow it down a bit... my second gear syncro is reked and just slow downm the gearchange and its fine a rebuild is a big job if u dont got the know how on removin the box
mine does exactly the same, only when at high revs
just had new clutch fitted too
Mine does the same going into 3rd at high revs :angry: im just hoping its not doing as much damage as it sounds it is...... :(
my 86 gts had the similar problem (1st to 2nd at arnd 3000rpm or from 3rd to 2nd gear). i just changed the tranny oil (atf for 3sge m/t)...it's ok now! :D
wat oil u put in it... just normal oil or u put in a flusher or just change it?>
I just drained and refilled it with Dexron II compliant ATF (Total Fluide ATX)...
(although my motor is 3SGE w/ M/T)
I just followed Chilton's celica manual... :)
Cheers! Been meaning to buy a manual for a while :rolleyes: is the Chiltern better than the Haynes?
will try getting under the car at the weekend and let you know if ive still got probs after topping her up.....
lol it is funny reading about the celica gearbox cause i have an 89 celica and it cruches going into 2nd and recently started popping out of 5th when you put your foot down... i think i need a new gearbox..... :huh:
i got both manuals for 86-93 models by Haynes & by Chilton..
Chilton's is better :thumbsup:
sorry i was refering to 94 - onwards
toyota seem to make their synchros from soft cheese,usually 3rd gear and 5th synchros go,although 5th can crack and keep popping out .synchro are 30 euros for the ring,hub is usually alright but its messy taking out box ,need special tools,just send it to gearbox specialist, :P
Had the timing belt and a full service done on the car over the weekend - I mentioned the gearbox crunch to my mechanic and it seems to have disappeared for now - he must've done something to it... :blink:
My Haynes manual is for 86-99 Celicas...
it cover GT4? turbo - 4wd etc?
if so - do u have the manual number handy?
cheers
cheers
Nah. Says right in the picture, FWD models only. Sorry mate.
