Wheels
Mackers
Anyone got alloy wheels for a 2000 avensis?? IDEALLY 17 or 18" no matter about tyres, i'd buy new ones if needed, pls PM me,
Wayne :)
Nope not selling only just got them
Cars bieng lowered as i post this 40mm as that pic is a vmod lowering
I got the wheels for £450 from Fitcar based in Cannock, but they have branches everywhere
Some online places sell the alloys too
5x100 et 35 is what u need fairly common so get looking :D
  • 2 months later...
Hi Gregg, I've got similar 18" alloys on my Avensis. The problem I'm facing is they touch the inside of the rear arches (I think)- get a bad scraping noise when more than one person is sat in the back and I go over bumps or even ripples in the road. Any suggestions to what I should do to stop the wheels scraping?
Cheers
Ehtesham :help:
You say they are similar, but your offset could be way off.
What is the exact name of the wheel and tyre size?
I think the avensis offset is between 35...38 and the tyres I have are 215/40/17
Cheers
Ehtesham :help:
it could be down to the offset, mine sit in the arches plenty, and 40mm springs,
If they do rub itll be a case of cutting some of the arch liner and then angle grinding the arch metal lip too
Thanks chaps for replying.
The tyres are 225/40 ZR18 92Y and the wheels are MAS Italy. I'm afraid I don't know what offset means! As you can tell I'm a freshi to forums!
http://img210.imageshack.us/my.php?image=dsc073604ey.jpg
offset is the distance the wheels sit from the hub where the wheel is sitting
mine is 38, so therefore they sit wel inside the arch, the higher the offset the more the wheel sits from the hub, so an offset of say 45 the wheel will sit out more and is more likely to catch the arch
this is mine and it has been lowered by 40mm, yours seem ot sit directly with the arch line, mine sit inside the arch line hence no catching even with 5 people in on a run back from wales to the midlands
