Buying A Pick Up
GIDDLEPIN
I'm thinking of buying THIS It's advertised as one careful owner but I think it could be a bit hooky....
Do you think it would take much to get it through an MOT?
Cheers
Les
Les
Looks fine mate - you will need to get a rear fog light before use in the UK.
Also these ones tend to rust a bit although that one looks a minter - just check that it is actually as good as it looks :thumbsup:
I think there might just be a small bit of surface rust on the wheel arch - if you enlarge the photo you can just make it out - nothing to worry about but you should knock a few hundred off the price for this as you couldn't really call it concourse condition with this minor fault.
Les
WOW! You must have fantastic eyesight…..I blew it up to the max on high res and only just spotted the rust ..
Thanks, I’m sure I can get a couple of hundred off now :thumbsup:
I thought this was going to be a serious thread when I started reading!.............then i saw the pic!!!
But your not serious though are you!?
With air-con as well................Bargain Les :thumbsup:
I have been viewing this thread at work but the images get filtered, I thought it was a real thread.
It's not!? :eek: ;)
