2003 Rav Engine Trouble
tuzo
Hi all, new member so bear with me and apologies if this is already a topic discussed. I have a 2003 d4d and love it but have been experiencing a problem lately. when i'm shifting friom 3rd to 4th on any incline the engine light will intermittently come on and the car will lose power. i have to pull in and turn the car off to reset the problem. this is an obvious danger and any tips/advice would be appreciated.
As you say "when I'm shifting from 3rd to 4th on any incline" is it only on a hill.... may be fuel starvation as your on the incline.... ;) ;) ;)
Any more details would help us...like does it happen on a straight road etc
it has only happened once on a straight, but again this was a few 100 mtrs after an incline. any tips if it is fuel starvation? should i rev it up to 3000 rpm or so before changing gear?
It sounds very much like the problem described here;
http://toyotaownersclub.com/forums/index.p...3&hl=valves
I would make sure that the fuel filter has been changed first though.
Hope this helps
Hope this helps
many thanks, will look into it!
If it is the SCV valves, they are £185.06 per set of 2 valves delivered to any UK address, maybe a tad more to Ireland
Kingo :thumbsup:
Kingo :thumbsup:
many thanks, I'll talk to my mechanic (family friend) and mention it to him, and hopefully it'll save a lot of searching and trouble.
Tuzo.
