First Supra..
DonDavidson
i've been looking at supra's for quite a while now and am yet to decide which kind i should buy, i'd prefer it to be mkiv manual but im looking for insight as to which is the easiest to get used to, seeing as how this will be my first, any ideas?
With regards to getting used to one... they will be the same for both manual or Auto as its the size of the car rather than the gearbox which takes getting used to.
There is plenty of information on this topic on these forums. Try using search.
Failing that try a google search, there is even more information there.
Common sense would dictate that you work out your budget, see what is available to you, and then test drive and see what you like.
